I am not sure what you mean, it will bolt to the carrier only one way! The entire differential can be put into the case with the ring gear on the other side of the pinion, but the tractor will go backwards in forward gears. The shifter rails might not work correctly, but the issue you raise is not clear. Clearancing and setting tooth patterns are serious business, and an experienced mechanic is a good idea. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
