Posted by markinab on October 26, 2008 at 08:14:52 from (68.182.128.212):
just replaced the mcv pump in my 966. took awile to get air out by running tractor, and everything was working good. Now whenever the tractor is shut down for more than 10 min. I loose mcv pump pressure and have the let tractor run for 10 min to get preesure back, almost like something bleeds off. I have had the pump out twice, no cut or missing seals. This is killing me! Tractor has hyd. assist clutch, ta, steering and brakes running off this pump. none of these functions work so definatley pump problem. dirt in a check valve maybe?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
