Posted by JimB2 on November 02, 2008 at 05:16:16 from (199.246.2.9):
In Reply to: 464 brake problems posted by Mike A on November 01, 2008 at 13:48:42:
Hi Mike, has anyone had the hydraulic lines apart by the front of the battery? There is a restrictor valve in the high pressure line to the brakes. I believe if the restrictor valve is missing there will be to much hydraulic pressure applied to the braking system and cause the brakes to come on. Have you checked the actual brake cylinders under the battery to see if they are sticking open?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
