A dual cylinder Saginaw will lift a lot more than tractor will handle using belly pump. I have used Saginaw on early SM and M for since early seventys, it works great with 4 row cultivator and will lift 4 row planter if you can keep front end on ground we used about 240 lbs front weights and tractor would easily lift front off ground.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
