Hi Darcey, here is the story from parts book. MN Scott is correct part is no longer available and to use new part you have to change the water pump carrier and some other parts. See below:
706/756 D-310 prior to engine number 52-P-728
Item 15 p/n 3055998R92 THERMOSTAT THERMOSTAT
Item 9 p/n 3056000R1 CARRIER/Retired CARRIER - water pump, no longer available, order thermostat 3228046R1, gasket 3059672R1, hose 3132912R1, carrier 3136678R2, plug 20972R1, elbow 3132142R2 (715 combines) or elbow 3132909R1 (all other machines)
706/756 D-310 after engine number 52-P-728 also 95/715/782/686 and Hydro 86
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
