Posted by Old-F20 on November 14, 2008 at 17:28:24 from (71.7.98.117):
In Reply to: pto lift off an F-20 posted by 686142 on November 14, 2008 at 15:41:05:
kevinjg said: (quoted from post at 16:41:05 11/14/08) i just took the rear mounted lift off my 37 F-20 it mounts to studs off the diff cover and has handles on each side for adjustments it wieghs about 150 lbs,it works fine ,my question is does this have any value and if you would sell it what would be fair?the part that slips over the pto is stamped ih so i think its a factory piece.
if you have every nut and bolt and it works then you've got something. if your missing even one part then finding that part is next to impossible which will significantly hurt the value. I personally would not have one on a tractor unless you had something like a mounted plow, or cultivators. without and attachment they're fairly useless :?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
