put a large 4 ft pipewrench on the pto,it is a better ratio than the trans. have someone pull or put weight on it put a good piece of hardwood on the piston and smack it with a sledge.i tried the pull with another tractor deal years ago and busted some main bearings,the jack under the crank only works if the crank is in a perfect spot
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
