Posted by Owen Aaland on November 24, 2008 at 09:59:24 from (65.165.246.117):
In Reply to: pulling dampner posted by John having problems on November 22, 2008 at 14:23:38:
I missed on what three bolts you were referring to. The crankshaft also has a small hole in the middle to center the puller forcing screw.
If the crankshaft still has just a plain woodruff key in it to locate the damper, is is a good idea to replace it with the updated key which is a little longer on the shaft so that it stays in place when the damper is pulled back on. There have been many dampers destroyed when the original style key moved a little in the keyway during installation and cracks the hub.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
