Hi Chris, I have a 2606 with 3000 loader and case 33(s)(I forget now) backhoe.
I have more hydraulic and steering issues right now among other things. Maybe we can visit sometime about them. I wonder how much of a job it is to replace the clutch with that loader and hoe on it.
Not sure I can help you on the direction reverser. Mine has a different problem. The direction reverser popped out of gear going forward at any speed or when pulling hard. Kinda identified one gear that was the culprit. Have to look at the IT manual to ID it. Was told about that on this board. When I looked at the manual that came with it from the previous owner, I noticed someone had written in a price for that gear in the drawing. An expensive fix along with a split. Anyway I temporarily fixed it with a 3" x 1/4" bolt with a washer and piece of fuel line hose and then double nutted it. Found the fartherest point forward the shifter goes and drilled a hole in the side of the dash. Then I slide the shifter behind the bolt to keep it from kicking back out of gear. Works so far. Mine has a little grind sometimes going into gear and sometimes none. Not sure if a clutch or synchronizer issue.
I'm not sure I have an explanation for your problem and apparently so far neither has anyone else. You can go to the caseih.com website and pull up and print out the diagrams and parts lists. Not sure if the direction reverser shows up under 2606 but you can find it under the 606 and 656. Those tractors use common parts and the manuals don't always reflect what you have. I find stuff listed under the 460 & 560 also since the 2606 is kind of a hybrid and these models all share the same IT manual. The hydraulic system shows up under the 656.
The direction reverser also had a neutral. It will run and spin the gears inside in forward or reverse (but not neutral) even with the tranny out of gear. Not sure what to tell you except look at it and shift if with the cover off and running and not running to see if there are any problems. Could be a broken ring or spacer or something. Run a magnet or your hand (not running of course) around the bottom of the tranny case to see if you get any metal pieces or drain the case to look for some. May need to drain it anyway to watch your gears. Look for any broken teeth or the edges of the teeth where they mesh together on the gears.
Post back with what you find out. Maybe someone else can add something here since I don't know much.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
