Posted by Gary T. on December 11, 2008 at 02:04:05 from (193.200.150.45):
I have a Farmall Super M. Which I bought last summer. When I got it, one brake held, the other did not work at all. I took apart the bad one and replaced the disks, cleaned everything up, and put in new balls and springs. I also found a lot of slop in the linkage piece that attaches to the pedal, so I had a friend weld the elongated hole to make it round again. I was very careful to be sure everything was sone right.
Now, the brakes on that side lock up. I still do not feel they are the greatest brake, they seem to be either all ON or all OFF, not much in between. On a hill, I still have to put every ounce of effort I have to hold the tractor in place. But that replaced brake locks up tight, so I have to keep backing up to release it almsot everytime I use the pedal firmly. I've taken it apart several times again, reversed that center piece (from side to side), and tried other adjustments. No matter what I do, it locks up and is still a poor brake until it totally locks.
The side I did not work on is also a poor brake, but does not lock up.
Either way, I am not happy with these brakes. Before this tractor I had a Farmall H with band brakes. Even with worn shoes, that tractor stopped much better.
I know the standard M tractors have band brakes. If I replace the housing, can I change this Super M to the band type brakes? I've spent a fortune on these disk brakes and all they do is irritate me. If I cant change it, I will likely sell the tractor and get a standard M. These brakes are dangerous, and I've run out of ideas how to fix them.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
