Sure it will, if its converted to a 12 volt genny it will charge a 12 volt battery, thats the whole idea. Actually, while I'm NOT recommending this (its NOT engineering correct) I've used 6 volt gennys as is no conversion and just changed to a 12 volt Voltage Regulator and they worked okay (it can overcurrent the field windings ya know). A shop can convert it from 6 to 12 volts and will change out the Field windings and do it right, however. Or just buy a used or rebuilt already 12 volt genny.
Of course, you also need a 12 volt Voltage Regulator if you stay with a generator and use a 12 volt generator,,,,,,,,,,,, Change any lights to 12 volts,,,,,,,,,,,,EITHER use a new full true 12 volt coil (NO ballast required) or else if you use a 6 volt coil add an external voltage dropping (12 to 6) series ballast resistor after the ignition switch but before and ahead of the coil.
If you wanna change polarity the ammeter leads need swapped or it will read bass ackwards,,,,,a coil should match the battery polarity, i.e. at Pos ground its lil - terminal gets ignition switched voltage input while its other lil + wires to distributor but at neg ground thats reversed.
Dont forget to POLARIZE the genny BEFORE you start the tractor !!!!!!!!!!!!!!!!!!!!!!!!
If you go with an alternator instead most all require Negative ground.....
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
