Re: freeze plugs on SC
Posted by ScottyHOMEy on December 15, 2008 at 16:41:05 from (70.105.224.63):
In Reply to: freeze plugs on SC posted by thumbanger on December 15, 2008 at 16:33:04:
There's two back there, but only one is a freeze plug, facing the water jacket. That one is 2".
The other one is at the back of the cam, so there's no water on the other side of it, only oil. Than one is 1-5/8".
Common sizes. Any NAPA should be able to come up with them pretty easily.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
