To run the rototiller, the engine needs to be revved up, but the tractor must be going so slowly that you can barely see it move. 1st gear on a Super A is more like a brisk walk.
The Super A does not have live PTO, so he can't push the clutch and chew through a tough spot. When the clutch is pushed, the rototiller will also stop along with the tractor.
The PTO on a Super A is offset. This will put a nasty angle on the drive shaft to the rototiller, and it will shake apart in no more than a few minutes.
There are a few tractor mount rototillers that have their own engine, and could be bolted to the drawbar. Even so, the Super A in 1st gear at an idle may be too fast to do a good job. You really need a more modern hydrostatic-drive tractor to run a rototiller.
If you want to get him a rototiller, get him a nice Troy Built rear tine from Home Depot or Lowes.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
