Re: md,400,450 diesel engine query
Posted by Janicholson on December 27, 2008 at 09:38:24 from (68.112.156.69):
In Reply to: md,400,450 diesel engine query posted by shoogiesty on December 27, 2008 at 08:59:14:
Interesting,
Most engines, while in operation, do not touch that area of the cylinder at all. Thus there is no reason for deposits to "wear" off. But if all had the Sooty deposits, and very much if, the tractor had been operated under load for at least 4 or 5 hours prior, I would suspect it was using oil pretty heavily. If the tractor was not brought to temp in the last few times it was run, I would say it was very normal.
Personally I think diagnosis by pulling the head may have been (with respect) premature. Diesels (especially the options with the gas start/diesel run engine) can be diagnosed to high reliability fault finding with the head on. Particularly the fuel injection system.
What to do now:
turn the head to a position so that the intake and exhaust runners face up on the bench (with the valves and injectors, and not the spark plugs, are in place). Tap each valve with a plastic hammer to make sure it is seated (crud can get into the face seat during disassembly). Then fill the manifold runner to each valve with diesel fuel. If fuel runs out the valve to head interface, the valve (or seat) is bad. If after an hour some diesel gets through I'd say it is OK. Some will get through the guides, if dramatic, the guide is bad. If it leaves the runner, but ends up in the water jacket, the head is cracked at the runner.
Set the head so the spark pluge are up. Fill the compression relief chambers with diesel. the third valve should also hold the fuel as above.
I would have the injectors tested at a good diesel shop, (if it had been still together, cracking the fittings on one cylinder's injector line at a time to find the miss, followed by compression checks and swaping injectors from cylinder to cylinder would have been my method of testing. Best of luck. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
