Posted by Owen Aaland on January 04, 2009 at 18:48:52 from (65.161.86.88):
In Reply to: polerizing question posted by bawplank on January 04, 2009 at 16:53:26:
The hot wire to the generator is disconnected each time the contacts open in the regulator.
Polarizing a generator results in magnetizing the pole shoes. The residual magnetism in the pole shoes create the magnetic lines of force necessary for the generator to start charging. As long as so magnetism remains in the pole shoes the generator should be able to start charging. Which way they were magnetized will determine whether it will charge with positive ground or negative ground. Polarizing each time a battery is installed is a good way to insure that if the battery is installed backwards the regulator will not be fried.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
