Re: Farmall A generators
Posted by Janicholson on January 07, 2009 at 15:55:16 from (64.83.227.252):
In Reply to: Farmall A generators posted by rrogers on January 07, 2009 at 13:38:27:
All the IH/farmall 12volt Generators are basically the same chassis. Differences are found in shaft length, and pulley adjustment systems. My way of figuring it out would be to check caseih.com for a look at the parts list of the doner tractor to see if it has the same pulley. Hugh, or CNKS or others may have better specifc info. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
