Re: Return to Oil pan gasket removal
Posted by Ed pap on January 25, 2009 at 08:18:45 from (74.47.171.70):
In Reply to: Re: Return to Oil pan gasket removal posted by John Athey on January 24, 2009 at 05:32:45:
Hello John,
I can't say for sure what the factory set up was. A good rule of thum on pan bolts is if there is a heavy steel strap then lock washers if it's just tin then a flatwhasher and a lock. if the holes are dished in, then take a flat bar in a vise and hammer the holes flat. I tighten the bolts with a 7" rachet "tight" and if it is a cork gasket I retighten them after the engine was warm. Loctite will work if you get the threads completely free of oil but I would not use it on oil pan bolts it realy isn't needed.
Godd Luck Ed
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
