Posted by t martin on February 06, 2009 at 13:15:52 from (206.176.202.57):
I have a 43 H that was just through the shop. Sleeves, pistons, head, crank, etc. The tractor is running now. It is fine at low and mid range but when opened up to full throttle and put under load it falls on its face. The main jet settings seem to have no effect on the problem but I know everything is clean in there. It has new points, condensor, cap, rotor, plugs wires, plugs, and coil. The points are gapped at .020. Any ideas as to what would cause this high rpm hiccup?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
