Posted by CNKS on February 06, 2009 at 18:42:59 from (216.144.104.128):
In Reply to: h timing posted by redplower159 on February 06, 2009 at 14:56:43:
Set TDC on # 1 as Bernie says. If the rotor does not point to #1, remove the distributer, rotate until the rotor points to #1 and install in that position. Do not try to "compensate for the meshing of the gear", (whatever that means). The distributer will mesh properly without moving the rotor from #1. After the gears mesh and distributer is inserted all the way, rotate it conterclockwise. Remove the coil wire from the distributer cap (switch on), hold end of wire 1/8 inch from the screw/nut on the dist that the small wire from the coil attaches to, rotate dist clockwise, viewed from the rear, until you get a spark. Tighten the distributer. It is timed. As a final check rotate engine one full turn, and check for spark again with the coil wire. If it does not start after that, it is not timing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
