Just put the red arrow plug back in a add another half gall to gallon and wait a while it will run slowly up to the front check yellow arrow. Then double check both plugs after a bit. As for the other hole underneth, that is a drip hole for leakage past ta seals to escape. Should be using Hy-tran or equivilent.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
