Which gear is broken? I"m in the process of rebuilding the tranny on a 130 which is basically the same as the SA. The I&T Manual is very good. I ordered a chassis service manual from Binder, it"s not bad but there are some typo"s. Take pictures before you take things apart. Keep all the gears together on the shaft in order they came out. You will have to punch out a pin on the reverse gear before the main shaft will come out. I had to go into mine because the oiler gear broke. Waiting now for parts before putting it back together. Good luck.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
