Re: Farmall 300 or M
Posted by farmall300u on February 18, 2009 at 16:46:22 from (70.189.145.171):
In Reply to: Farmall 300 or M posted by Ardie on February 18, 2009 at 16:29:00:
Depends if you need live pto, power steering and live hydraulics. No question the M is a much simplier tractor then the 300 to keep running.
On my 300, I had to replace the three hydraulic values, pump, pto clutch and TA. Not cheap to get parts and the knowledge to do the projects.
The old M with the belly pump, straight drawbar and straight pto never has a problem you can't fix.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
