Posted by ScottyHOMEy on February 24, 2009 at 10:35:43 from (70.105.240.166):
In Reply to: Re: super a seals posted by ScottyHOMEy on February 24, 2009 at 07:37:58:
about doubling up the seals.
I touched on it in answering about the axle seal, but, yes, the shells on the newer seals are not as thick as on the old rawhide variety, and it is common to drive two of them in to replace of the old. This can, but might not necessarily have the advantage of putting your seals on a a new surface that hasn't been worn down by grit on the old seal. If so, great! If it continues to leak, you might need to look into disassembling and putting a speedi-sleeve on the shaft.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
