Posted by mkirsch on April 17, 2009 at 05:42:50 from (64.80.108.55):
In Reply to: repower posted by roy prins on April 14, 2009 at 16:42:13:
The only semi-bolt-in option is the diesel out of a Farmall 350. All else will require custom machined back plate, fabricated front engine mounts, etc.
If you wanted to get totally crazy, you could use the engine and frame rails out of a 460 diesel, 656 diesel, 666 diesel, or 686 diesel and go 6-cylinder. They share the same bell housing bolt pattern as the H-350 platform. Of course then you'll need to lengthen the hood and figure out how to install the H's front bolster...
Problems with an automotive diesel is the lack of a governor, and the engines turn about twice the RPMs of an H engine.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
