Unless your pump has started pumping engine oil with your fuel, or one injector sleeve goes through an oil passage, it is likely a leaking injector. Partly burned diesel is a black, sticky liquid that at first looks like dirty engine oil. As the leak gets worse, it will build up and form a very hard, shiny, sticky layer of black ooze that will spread outward from the injector. It is EXTREMELY difficult to remove (chisel, screwdriver, putty knife, and lots of chemical cleaners). I let it go a year before I cleaned the sleeve and replaced the injector and brass sealing washer and it took 10X longer to clean than it did to replace the injector.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
