There's obviously been some cobbling going on -- not unusual on a tractor that worked for a living.
If there's no sign of a pulley anywhere near the inlet to the motor and the lower radiator hose, it's a pretty safe assumption that you don't have a water pump. The pump (they're still available) bolts up to the very same holes in the block as the simple, no-pump, inlet. If there's no pulley there, there's no pump.
As long as there's no thermostat in the outlet (between the head and the upper radiator hose), the lack of a pump should not pose a problem in any but the heaviest work for your tractor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
