Posted by ScottyHOMEy on May 14, 2009 at 20:20:11 from (70.105.247.67):
In Reply to: rear wheel bolts posted by lisa massie on May 14, 2009 at 19:04:51:
They're available as regular hardware goods from any number of sources. If you have a Fastenal store in your area, that'd be a good place to start. I can also recommend Earnest Machine Products who can be found with a quick google.
I'll suggest that you go ahead and get new nuts and lock washers while you're at it.
Overall, hold your breath and clap a lid on your surprise. Especially in small lots, you'll find them to be quite precious, i.e., not cheap.
What you're looking for are Grade 5, 5/8" NC x 3" bolts and the nuts and lock washers to go with them. NC indicates coarse, as opposed to fine, thread, and Grade 5 is the standard -- ungraded bolts are usually Grade 2 (too soft/not tough enough) and Grade 8 is too brittle for the application. The specs in the parts catalog are for 2-3/4" long but you won't find them. The 3" will be fine.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
