Unfortunatelly , the melting of the fuse block is a common problem. Too many lights on tractor for that style of fuse holder to handle and same for the cab relay which is the other problem fuse. Co. recommended repair is remove fuse holder, locate affected wire, cut them off and install circuit breakers. 50 series were same only harder to work in that area due to the sentry being mounted in there. As far as replacing the fuse holder assembly itself, it is a real night mare and you may have same problem all over again. Short circuits will pop a fuse right now, where as a heavily loaded circuit will over heat the contacts fuse fits in and eventually melting it out.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
