Posted by Bill Teeters on May 18, 2009 at 17:00:32 from (67.77.224.2):
In Reply to: pto shaft loose posted by the tractor vet on May 17, 2009 at 15:41:50:
Bill Teeters said: (quoted from post at 23:41:50 05/17/09) My super c pto shaft is leaking and loose. I took the pto off the tractor and the shaft is just flopping around. I need to pull the gear with a puller, I think. I can see some of the casting has broken and it is behind the gear. Is the pto ruined or will a new seal hold the oil and shaft. The tractor is used for grass cutting and my son took the over running off and I did not notice it. Where can I get a pto if needed? Should the bearings all be changed?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
