The system you are working with is the added crankshaft driven hydraulic pump. The relief valve is in the end plate of the valve stack. If you add any valves to the return line you must also add a relief valve because the one that is there now dumps the relief pressure internally to the return hose port. It cannot provide protection from any obstruction (such as another valve assembly) from that port to the reservoir.
The easiest is a mentioned earlier, just add to the valve stack with the same type of valve and use longer bolts. You can add as many as you have room for.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
