PaulW_NJ said: (quoted from post at 05:08:02 05/22/09) What I found is you cut the two rubber hoses to drop it out. My cast elbo was jammed clogged with rust and sediment. Clean it up real well, inside and out. If you cut your replacement hose stubs a little long, and coat the inside with dish soap, you"ll be able to slide both ends so you can get one end on, slide the elbo in past where it needs to end up, get the other end on, and then slide it back in the first hose to it"s final position. That"s probable clear as mud, but I hope you get the idea. Worked for me, but you can"t do it without new hoses.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
