Compression check: All plugs out. Throttle wide open. Battery charged. Tested to be good and accurate gauge crank engine for six strokes on each cylinder. Write down the numbers. Repeat with two squirts of engine oil in each cylinder. Write down the numbers. Each should be within 10 % of the highest reading. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
