Posted by Doug - Iowa on June 02, 2009 at 05:32:24 from (71.32.179.33):
In Reply to: Help ID Older Hayrake posted by Illinois Farmall on June 01, 2009 at 19:53:51:
That would probably be a IH #10 rake. Very dependable and easy to work on, at least in my experiance. The gear box will gather water, be sure to drain it and change the lube every spring. Mine leaks a bit so I use corn head grease for lube.
#13 and #35 are simular but you said the shaft went from the sproket to the gearbox, which should make it a #10.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
