Posted by The tractor vet on June 08, 2009 at 06:43:33 from (99.167.208.210):
In Reply to: high range park lock posted by cjd12000 on June 08, 2009 at 04:04:53:
The gear that you have teeth knocked off of is the rev. driven gear and that gear is the last gear to come out and the first one that has to go in and it is a job to replace as for it jumping out of high look real close at the cam on the shifter and your detent spring and all the small rollers and the sifting fork . If you have it split between the speed trans mission and the range transmission look at the shifting collar and the end of the output on the speed trans mission for waer . When going back together use a heavy rubber band around the input bearing on the range transmission to help hold the rollers tight as you can and will knock them off when going back together . Do not worry about removing that rubber band as in time it will just go away
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
