Posted by Will P on June 08, 2009 at 14:12:01 from (67.53.144.50):
First, I am a Deere guy working on my Fathers H. This is the second block because the first one was total junk. Had to heat up the sleeves to get them out. Pulled the dry sleeves out, and the bores they go into clacked about 1.25 inches above the bottom of the bore. I am sick and tired of dealing with junk. Is this common for a dry sleeve engine to crack. Can I weld the bore, grind it down, and put a new sleeve in? Or just junk this block too??? Anyone have a running H engine around Milwaukee Wisconsin??? I need to have this running in about one month.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
