Posted by chad from michigan on June 12, 2009 at 09:12:13 from (151.163.3.10):
Ok guys I have talked with several of you before and I do not want to here to go through the trouble shooting guide I have it and its helpful. But I remember Janicholson telling me how to adjust my VR by adjusting the spring tension on the little coil to change the charging output. Anyway I installed an aftermarket generator/hyd unit all in one on my Farmall A. Its an old Chrylser generator with HYd to lift the old convertable tops. Anyway that doesn't matter. I installed a VR that I had and it once I pulled the cap and adjust the spring tension it started charging at about 12amps. I installed the cover and it stops charging, take cover off it charges. I remember Janicholson telling me the cover may cause the magnatism to change. Is there anything I can do so that when I have the cover on the vr will work? Thanks for any help. Chad
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
