Posted by Wardner on June 19, 2009 at 17:24:17 from (4.154.241.179):
Shot from rear. Motor is a Prince PTO pump with 1 and 3/8th six spline bore all the way through. Pump is a Super H - 350 live pump. Air actuator is from a truck air brake system. Outside bearing (black color) and PTO shaft is from an Oliver 60 Industrial. Throwout bearing and shaft is from a 400 TA clutch. My only purchase so far is the formed steel box @ $90.
Shot from front.
Flow control valve for variable speed. Not yet mounted.
It will be a couple of weeks before I road test the Hydro-Creeper. I have alot of plumbing to do on the air and hydraulic systems.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
