Posted by screwstick on June 28, 2009 at 16:28:27 from (75.88.125.88):
In Reply to: stuck piston c-60 posted by rterry on June 28, 2009 at 05:50:47:
Is the piston at the top or bottom of stroke? The piston cannot be removed through the bottom of the cylinder. If there is a ridge at the top, it has to be removed before driving it up through the top.
In addition to the heat trick, mix A/T fluid with acetone and let it sit. It will do a better job than PBblaster.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
