Posted by scott mcintosh on June 29, 2009 at 20:45:24 from (216.180.197.23):
In Reply to: 806 mvc gear replace posted by josh braman on June 29, 2009 at 19:32:06:
You will have to split tractor at clutch housing,remove bolts from bearing holder,then remove bottom plate,also remove input shaft assy. then there might be enough room to slide gear of shaft then out bottom. If there not room then it will have to be split again to gain more room.This all from memory it's been awhile.Any more questions ask for the Tractor Vet.Scott
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
