Posted by jimb2 on June 30, 2009 at 17:22:35 from (99.240.236.11):
In Reply to: Loader plumbing/ 574 posted by m stas on June 30, 2009 at 14:42:50:
Hi there is a hydraulic return line that goes out of the top of the last aux remote valve on the right side of the tractor to draft control under seat to the rear. You have to lift the seat deck to access the return line. The line looks like a L with a bit of S curve on rear end. Remove this hydraulic line from elbow at top of aux remote control and connect inlet of loader control valve to this elbow. Connect the outlet of loader control valve to other fitting where the hydraulic line went into the draft control assembly.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
