Posted by Janicholson on July 04, 2009 at 09:30:01 from (64.61.211.159):
In Reply to: 656 int. charging system posted by R Cummins - Missouri on July 04, 2009 at 09:13:38:
Charging all the time is a good reason to make some checks, but not a condemnation of the regulator. With it running at 3/4 throttle, put a good analog (needle style) volt meter on the battery's posts. It should read 14.2 to 14.4 volts (lights off). If it is, it is OK in the charging department. If it is 14.7 or more, I would replace or adjust (takes special procedure)the regulator. If the battery has a partially shorted (bad) cell, it will charge all the time as well. The voltage will be as above, but the battery will continue to be trying to be charged. Usually this results in loss of battery "water" in cells, and heating of the battery. Good luck, JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
