The lifters are down below in the cover behind the distributor. The things up top are rocker arms, push rods, and valves. (springs on valve stems are visible) The Fuel is an unknown, Unless there is a bunch of fuel in the oil from leaving the tank valve on all the time, there should not be fuel there. Antifreeze can be from a head gasket, a cracked cylinder, cracked head, or a bad core plug (Freeze plug is the wrong name). Putting about 7 PSI (MAX) in the radiator will show you the leak. You may need to take off the oil pan to find it, if it is not in the top end. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
