The answer is yes. The Easiest is to use a Hitachi alternator from a mid 80s Nissan truck. It is small and easily fits. It wires with the L terminal connected to the same Diode or lamp (idiot light) then to ignition, as an 10SI Delco. The other terminal S connects directly to the big output terminal. A 10SI will also fit but has much less room. The existing bracket is turned upside down, and all thread is used to hold the main pivot point. A new adjuster will also need to be fabbed. THe belt length is critical and needs to be measured to just fit. There are thousands running Delcos W/O cutting the hood. As to a Kit I would not use one, See Bob M wiring diagrams to get the scoop. A one wire system is harder to get charging, and often has a drain when not being used. JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
