Posted by Henry Retter on July 22, 2009 at 08:19:39 from (72.237.167.11):
In the process of removing the radiator from my 1951 M, I removed 2 bolts and loosened 2 studs that hold the fan blade to the water pump. This allowed me to tilt the fan and remove the radiator with the fan shroud still attached. Once out of the tractor, I removed the last stubborn bolt holding the shroud to the radiator. One of the fan blades is cracked close to the pulley, so I want to remove the fan to weld it. How do I remove that contraption (called a driver in the Case-IH parts view) from the water pump? There is a bolt in the driver that unscrews, but then what? Thanks.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
