Re: Farmall C step?
Posted by Hugh MacKay on July 26, 2009 at 02:41:07 from (216.208.58.115):
In Reply to: Farmall C step? posted by bigr on July 25, 2009 at 15:51:47:
bigr: Yes, I've seen a couple of versions, local fabrications, in both cases it clamped to rear axle carrier. Someone had done a neat job on both. I've also seen a couple others that may be functional but didn't look very neat.
I've also seen a couple of larger fast hitch tractors, where they extended platform both width and forward around the clutch pedal for mounting ahead on left rear wheel. Been a lot of minor injuries over the years using fast hitch for a step. I have a couple of scars on my legs from foot slipping on fast hitch on a 560. Had a friend with a 200, always managed to get it in the groin when his foot slipped.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
