Posted by pete 23 on July 28, 2009 at 10:34:35 from (173.87.13.168):
In Reply to: SUPER H HYDRAULIC posted by james barker on July 28, 2009 at 08:28:00:
If a lot of oil leaks just when you pull lever, it sounds like you blew what they call the manifold gasket on the pump, and you need to remove pump and take it out of it's reservoir case to get at the bolts inside. Not difficult except engaging operating link when reassembling, I put internal linkage to raise position and put a vise grip on outside portion of lift lever and feel it in to place, and lifting pump back in, couple guys with a rod through bottom or floor jack.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
