Posted by Richard S. on July 29, 2009 at 15:40:04 from (70.3.147.88):
I have been using an IH 986 and plan to buy, but it has developed a problem. I need some help!The Hyd - trans indicator light stays on until you get above 1500 rpm, and the power steering is also very very stiff until you get to higher rpm. When the clutch is depressed, the indicator light comes on irregardless of rpm. Even worse, the tractor won't move until you get to higher rpm and then it will lunge, almost throwing you out of the seat.
We have changed the hyd - trans filter and have checked the oil level. It is a late 1978 model with a TA. The TA has not worked in years but they have always kept it in the high position and not had any problems until now.
Does anyone have any ideas? I would like to know something before I buy the tractor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
