The T/A has a small clutch in the center housing. Dirrect or high T/A depends on it holding. If the shaft that goes in the center housing that the T/A handle linkage goes to turns clockwise (looking from left side of tractor) enough to move the T/A clutch release bearing away from the pressure plate fingers, adjustment is not the problem. If it happened all at once with no noise, the splines may be worn off that clutch plate drives from. T/A pressure plates usualy make some noise when they start comming apart. If its not adjustment problem you can remove plate on top of T/A housing and see T/A clutch.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
