gmd said: (quoted from post at 18:25:15 08/06/09) on my fathers 340 the ta just stopped working one day when he was using it. It is stuck in the low side. he said it didn't make any noise- no grinding/banging/broken mechanical indication. Knowing very little about the innards of a ta, is there a way to tell without tearing everything apart whether or not its an adjustment issue?
Thanks!
Unless the TA clutch lever is stuck in the released position the failure is in the TA clutch. If it still has the original disk with woven linings the most likely problem is the lining coming off the disk. The rivets can come loose and the lining fall off or more likely letting the tractor coast down hill in the low TA position. That over speeds the disk can cause the lining to come off even if the rivets are tight. Replacement disks are bonded metalic lining that handles the speed much better.
The clutch can be inspected by removing the cover on top of the clutch housing, the stamped steel one held on by four bolts. The TA clutch can be replaced by splitting the tractor at the engine clutch.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
