not an uncommon problem for the disc to stick. if you can get the tractor pointed in a safe direction, get it started and warmed up in neutral. then shut it off, slip er in 3rd or 4th, block the clutch pedal down with a 2x2 that you can easily remove from the operators platform, then start it up and drive around. stomp the brakes several times to see if you can get the disc to break loose. it should pop loose. once you get it loose, slip the clutch a few times to get the rust off. prolly need to relube the throw out and pilot bearings too.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
